Hello, is it possible to generate netlist version D using kicad 6.0.1? I have to run some scripts on the netlist file but kinparse ( https://github.com/devbisme/kinparse ) is unable to parse the version E generated from the last version of eeschema.
I had a short peek at:
https://dev-docs.kicad.org/en/file-formats/
But I see no description of the netlist format. Maybe it’s just overlooked.
I wonder if it would be a good idea to file a bug report for that (I have not checked gitlab yet).
It is not possible to generate old formats of netlist.
I updated kinparse
to handle KiCad V6 netlist files. You can install it like this:
pip install git+https://github.com/devbisme/kinparse@kicad6
You don’t need to tell it whether you’re using a V5 or V6 netlist, it should work with either one. Let me know if this works for you and then I’ll merge it into the master
branch and put it on PyPi.
I fixed an error in kinparse
and verified it was doing the correct things when parsing either V5 or V6 netlist files. I have released it to PyPi so it can be installed the normal way:
pip install kinparse
