I am trying to create a GenCAD output with fiducial pads on the top and bottom layer. When I export with GenCAD, it only shows the pad on the top layer and not the bottom layer.
What do I need to do or change to get the fiducial on the bottom layer to be exported as well?
Didn’t know about it.
But info that it only shows pad on top and not at bottom suggests that there is probably somewhere GenCAD file format viewer and that viewer does’t show what is expected. So it can be KiCad problem or viewer problem. Knowing what viewer and example file would be helpful.
GenCad is unfortunately a poorly-supported (and not widely-used) format. I would strongly recommend switching to IPC-2581 (available in 8.0) or ODB++ (available in 9.0). Both of these exporters are getting active bugfixes and testing; the GenCad exporter has a number of known issues and isn’t being maintained as well.
The problem is I have a fiducial footprint with one fiducial pad on the top layer and the other fiducial pad on the bottom layer. When I run File>Export > GenCAD with no options checked as shown here:
The output defines the shape of the footprint with two overlapping pads on the TOP layer only instead of one pad on the TOP and the other pad on the BOTTOM. This is what is generated: SHAPE "Malmoset_Fiducial:FID_020" INSERT SMD PIN "1" PAD7 0 0 TOP 0 0 PIN "2" PAD6 0 0 TOP 0 0
Contract manufacturer we used for years didn’t asked for fiducials ever so I even din’t know what it is (now I suppose that they just added them when making a panel with our PCBs). When we moved to new contract manufacturer he asked for fiducials.
I have made fiducial footprint with mark only at top. This gives you more flexibility - you can place them only at one layer, and if needed at both you can place them as you have a room for them (sometimes it can be the same positions for top and bottom).
Using only top layer fiducial footprints can be a way-around for you (if works).
