talking about standard fp library item Fuse:Fuse_1812_4532Metric. I find at least three sources, that 1812 fuse footprint should look like 3.45mm - 1.78mm x 3.50mm:
F_1812 sources:
But Kicad library has ~ 3.16mm - 1.125mm x 3.4mm:
Is this a mistake in the library? Or is this kind of IPC standard? The problem is sucha, that real 1812 fuse would fit on kicad’s 1812 footprint perfectly, but wider pads should help to spread heat away from the chip…
Should I report this to library team (Issues · KiCad Libraries · GitLab)?
I wish to contribute to the library creation, but was not able to generate a thing 2 years ago when tried using KiCad / KiCad Libraries / KiCad Packages3D Generator · GitLab. I am running windows. Have anybody used (setup and running) this scripting thingy on windows machine recently? Maybe this scripting setup works only on several PC’s, belonging to library keepers, running old OS, or something like that…? My skills are better now, but still, afraid to setup everything again with no success. (I don’t like maintaining pretty generic footprints like this fuse or
Diode_SMD:D_SOD-128just because they do not come with 3D models, I would like to provide these models to the stock library, instead).
