I would like to add the ability to change the font of all text elements in my PCB in my script but this code is not working:
def Run(self):
board = pcbnew.GetBoard()
# Define the font name to change to
new_font_name = "Arial Bold"
for footprint in board.GetFootprints():
for graphicText in footprint.GraphicTexts():
# Change the font name to Arial Bold
graphicText.SetFont(new_font_name)
pcbnew.UpdateUserInterface()
but I get:
AttributeError: 'FOOTPRINT' object has no attribute 'GraphicTexts
I have no knowledge of python or the pcbnew library, how could I correct the function?
Thank you Coffee, I do this every time to change the font for everything, but I wanted to do it in a single step with a script, but I searched for it and I don’t think there are functions to do this.
I tried a more practical solution, this code generated by AI correctly modifies the .KiCad_pcb file and changes the font for all elements.
# Leggi il contenuto del file del PCB
file_path = board.GetFileName()
with open(file_path, "r") as file:
file_content = file.read()
# Definisci il pattern da cercare e il testo con cui sostituire
pattern = r"\(effects \(font \(size 1 1\) \(thickness [0-9.]+\)\)\)"
replacement_text = (
' (effects (font (face "Arial") (size 1 1) (thickness 0.2) bold))'
# Esegui la sostituzione utilizzando espressioni regolari
new_content = re.sub(pattern, replacement_text, file_content)
# Sovrascrivi il file del PCB con il nuovo contenuto
with open(file_path, "w") as file:
file.write(new_content)
# Salva il file del PCB
board.Save(file_path)
pcbnew.Refresh()
Is pcbnew.Refresh() and pcbnew.UpdateUserInterface() not refreshing the changes, is there a way to reload the pcb from the modified file (even with an external editor)?
I don’t keep up with Kicad’s changes - I tend to do things my way and that often means by Brute-Force programming (meaning, I let the computer do the work even if it takes longer to run codes…). Thus, I don’t know if Refresh does or, does-not work but, it seems to work for my plugins. They all work and never crash.
Not long ago, some started crashing upon updating to v7.0.9 but, not with v7.0.10
Screenshot show example with Refresh inside “def’s” and at end of them.
The PCB window has a Recycle/Refresh button that may help…
