Front Solder mask aperture bridgers items with different nets
Hello everyone:
I am making a 4 layer PCB, as is normal i define the planes, and the copper coverage of front and bottom.
But i get an unusual error on fiducial:Front Solder mask aperture bridgers items with different nets.
The spected behavior is simply an open on the copper plane.
As is possible see, the fiducial has no connection (of course) and there is only one plane (gnd). BTW if there is 2 or 3 planes this is not must be considered an error (unless i am missing something).
and GND are not the same net, so the error is correct, the Fiducial solder mask bridges items with different nets.
At least that’s how I read it.
But allways is this. You get an aperture on the plane to the optical centering of PnP machine. I am using the kicad library for the footprint, maybe a mistake on the library with an bigger opening on mask?.
There could be different reasons for this behaviour:
  • mask opening to big, so the mask opening really bridges copper elements from different nets. This could be improved if the mask opening in the library is reduced
  • the ERC check is not cot correct and the copper and mask are not overlapping each other. In this case this would be a bug
  • other reasons (which I don’t know)
To judge the situation a example project is needed (I don’t have the actual library versions available, so I can’t recreate even such a simple project myself).
Or you examine the project / board for yourself, and open a corresponding gitlab issue either reargding a ERC error or regarding a fiducial footprint improvement.
Until that you could simply increase the copper clearance for the fiducial pad to solve the issue for your actual board.
Yes, the footprint is wrong. Is possible see how the plane go inside of fiducial footprint.
This must be reported to the gitlab?
Sure, but first you should try for others to reproduce it, mentioning your Kicad version, the name of the footprint, from which library and it would be great if you shared a minimal project showing the problem.
I would still prefer sharing the example (minimal) project here first.
I create a new project for the example, and works good. Seem like some on the symbol import from Kc8.
Thanks to all
Finally i found the reason. I was place a zone cleareance 0 instead to 0.5. Even i think that keepout of fiducial must be good even if the zone cleareance is 0. But thanks to everyone.
