Freerouting v2.1.0 not working on KiCad 9.0.0
I’ve been using Freerouting v2.0.1 with no issue. Freerouting v2.1.0 became available as an updated plugin so I tried it.
It could no longer auto-route the relatively simple PCB I had just successfully routed with v2.0.1.
I have created a bug report on the Freerouting GitHub - I had to revert back to Freerouting v2.0.1 and it was then working fine.
Just wanted to give a heads up in case anyone was thinking of pressing the “update” button.
Or … in case it’s working perfectly fine for someone else … what am I doing wrong?
To revert, I downloaded the v2.0.1 KiCad plugin ZIP from the Freerouting GitHub and just copied over the installed files the KiCad plugin folder.
Brett.
I too can’t get Freerouting to run with 9.0.1. It complains about the JRE version on my machine even though I’ve used the Java cleaner to flush it and reinstalled the JRE via the link shown in the Plugin manager.
Interestingly, it works fine with 8.0.9 so that would seem to indicate the JRE on my machine is fine? Running the latest 2.1FR in both the 8.0.9 case that works and the 9.0.1 case that doesn’t
FWIW, I’m unlikely to use an autorouter, but I like the idea that I could. Thanks for the revert tip.
Thanks for the feedback Dave … and I do appreciate the “FWIW” comment :slight_smile:
Since battling with Freerouter in my Exelvision cartridge design (an obscure French computer using the TMS7220 microcontroller as a CPU) … it kept sticking tracks & vias between the cartridge pins, probably more due to my own inexperience than its own nefarious purposes … I’ve started doing some basic routing by hand, then letting Freerouting take over the rest.
Some further info from my install - maybe not for you but “for the record”. I’m using a Mac (2022 MacBook Air M2). Versions are below … Freerouting v2.0.1 works fine, v2.1.0 does not work:
Application: KiCad arm64 on arm64
Version: 9.0.0, release build
Platform: macOS Sequoia Version 15.3.2 (Build 24D81), 64 bit, Little endian, wxMac
openjdk version “21.0.5” 2024-10-15 LTS
OpenJDK Runtime Environment Temurin-21.0.5+11 (build 21.0.5+11-LTS)
OpenJDK 64-Bit Server VM Temurin-21.0.5+11 (build 21.0.5+11-LTS, mixed mode, sharing)
