After install of freerouting plugin it cannot be found in the usual place. The install location had a script that would copy to /home/ron/.kicad_plugins/kicad-freerouting-plugin so I created the dirctory kicad_plugins/ and ran it. It did create the sub /home/ron/.kicad_plugins/kicad-freerouting-plugin and put stuff there but no-joy.
Any solution?
Thanks
jmk
March 1, 2024, 7:04am
2
OS please.
Some operating systems are having trouble installing plugins.
Some plugins may not yet be updated to run on Kicad 8.0.0
jmk:
OS please.
And info about your Java JRE/JDK version.
Freerouting is written in Java and can be fussy about this.
$ uname -srm
Linux 6.5.0-21-generic x86_64
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
Thank you
No freerouting plugin under Tools->External Pugins
$ java --version
openjdk 11.0.22 2024-01-16
OpenJDK Runtime Environment (build 11.0.22+7-post-Ubuntu-0ubuntu222.04.1)
OpenJDK 64-Bit Server VM (build 11.0.22+7-post-Ubuntu-0ubuntu222.04.1, mixed mode, sharing)
Version: 8.0.0-8.0.0-1~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.16
Platform: Ubuntu 22.04.4 LTS, 64 bit, Little endian, wxGTK, X11, ubuntu, wayland
Date: Feb 23 2024 14:30:25
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.81.0
ngspice: 42
Compiler: GCC 11.4.0 with C++ ABI 1016
system
Closed
June 3, 2024, 5:28am
6
