Hello, i’m not sure if this is the right place.
i’ using nightly build (because of eagle import) kicad-r11631.4db550353-x86_64.
This looks quite ok (actual) but when i create a .ses file with freeroute i got for the “imported” holes (see at the end) an import error at Kicad PCB
erwartetes zeichen “image_id” in eingang/quelle
bad translation from me expected sign “image_id” in input/source
if i delete this (below) lines in the .ses file it can be imported and looks ok
thanx for info in advance greetings georg
(component
(place @HOLE0 1434560 -804586 front 0)
(place @HOLE7 1950910 -1298890 front 0)
