I’m playing with FreeCad with the KicadStepup workbench to get a 3d model that includes silkscreen.
It’s working pretty well, except the silkscreen graphics aren’t aligned. Probably related to this message I get when I open the Kicad pcb in the FC workbench:
Grid origin and drill origin are two kicad different settings.
Please refer to kicadSteUp cheatsheet for FreeCad import settings and kicad pcb settings.
It doesn’t seem…
If you have set grid origin the warning should disappear… (not related to your issue)
Moreover you probably missed to export Silk screen unchecking the drill origin box, as suggested in cheat sheet.
Thank you! Got rid of the warning. Will try importing the dxf for silk again.
Confusing, though. If there’s no grid origin in Kicad, how is it the X and Y values are displayed at the bottom of the PCBNew window? And, why does it show up under View->Grid Properties
It is not removed. If you look at the icon for the drill origin, you see a small black triangle in the lower right corner.
This means that it is a “fold out” thing, and you open a mini menu with different icons with a long click, and you can switch between the icons for drill or grid origin:
