So you’ve both got a monitor that’s around 2600 (2580?) pixels wide.
If Firefox is much wider, the “FAQ” text has the same distance from the right margin, but the rest of the forum stays in the middle, and the “FAQ” text is on the right side of the icons.
More important though:
Actually clicking on the FAQ link gives a security warning:
It looks like the “FAQ” text link was hacked into the forum software.
The most obvious “better” solution would be to make it an icon and integrate it with the Search, Hamburger, and Avatar Icons.
Perhaps an effect of your server swap over.
It was impossible to log in with the correct credentials.
Needed to go through a password reassign procedure.
I got logged out because it tossed my cookies but I had no problem signing back in. My browsers are set to toss cookies when I close them so I have to re-login on a regular basis.
Not sure what happened to you, I only had to re-login. Whether the server side session data is preserved across server changes depends on where it’s stored. Load balanced/redundant web services use persistent storage like a database. Back when I was in a server admin team, I also saw a shared NFS drive used.
After so many hours I do an F5 to reflect the most recent posts. This time the entire site simply vanisched like it did not exist. Today then the little re-login drama.
Not sure it’s related to the certificate, but it seems that links to forum posts inside another post are still using the 2020forum URLs (and lead to the “potential security risk ahead” notice).
For those still experiencing problems, what platform and browser are you using. I’m on Debian and using Firefox with all sorts of privacy and security extensions and have no problems. I actually have to switch to a less restricted browser to read some sites. I may have done some ‘exceptions’ on the extensions at some point for this site.
But I checked my achievements when I also received that “first link” badge, and I had all the old badges there. As if they were checked from the wrong place when granting new badges.
