I’m using a plugin GitHub - tywtyw2002/FilletEdge
But it’s not possible to undo the modification done by the plugin.
Is there a way to “save” the state before the plugin execution (In the python code), to be able to do an undo ?
Nope. It requires the plugin to use the correct API to leave undo information behind.
I’m planning to modify the pulgin to do just that.
But what is the API to use ? and is there some documentation about it ?
I’m pretty sure there is no API for it, pointers to it are welcome.
Heh, never said the correct api existed in python :whistles:
The modifications done by the plugin should be saved as an undo state when the plugin is closed.
