There are some strange cases when generating 3D steo files.
- I created a library using switches from ALPS.
There was no problem when viewing through 3D View,
The 3D files generated in 7.0.7 and 7.0.10 were different.
(In 7.0.10 and higher, the generated 3D was rotated 90 degrees.)
(The last 3D is Capture is created at 8.0.0)
- The LED 3D Step file is downloaded at 3dcontentcentral.
For the green LED, the generated 3D file has different colors.
I don’t know why this happens.
However, for some 3D files, what you see in the 3D view and the result of creating the 3D file are different.
(If necessary, we will create and upload the corresponding library.)
SMD_Tact_Switch_3.9x2.9x2H_SKRKAH.STEP (836.3 KB)
User Library-LED0603_GREEN.step (192.8 KB)
