Footprints Not Visible on PCB - OSX - KiCad 8.0.4
Hello Group.
I have a Kicad 8 question/issue.
Preamble:
I installed KiCad 7 last year - went through a Digikey 555 timer tutorial for it (very good) - and then made my first board in 20+ years. All went well. I now just installed KiCad 8, going through same tutorial for a refresh, but having an issue with seeing footprints on the PCB.
Issue:
When I “Update PCB from Schematic” I see the lines connecting footprints, but I see no visible footprints.
  • all components have been assigned footprints
  • there are no errors
  • all layers are visible
  • rat-nest lines are visible
  • if I right click on line where footprint should be, I see properties for footprint
  • if I try to add footprint manually - I do not see image of footprint in preview
So, kinda weird. I’m thinking some display setting issue, but it is not apparent what…
Some further info:
  • OSX 12.6.2
  • Kicad 8.0.4
  • Kicad 7.0.8 still installed but in different folder
  • Kicad 7.0.8 does not have issue
  • projects and libraries are in separate folders outside of Kicad
Any input appreciated.
Maybe similar to this:
Footprints are a few lines lower on the list.
All required Objects were visible in Objects tab.
Turns out if I save the PCB, close it, then open it again, I see the footprints…
They still dont show in preview for manually adding, but if I add, then save, close, open, I see them on pcb.
Maybe just a little buggy…
That is a possibility. I recently also had the PCB editor canvas go blank on me, and it “resolved itself” after a bit of fooling around (zooming, window resize, can’t remember). I was too distracted to investigate further.
I’d you can find a way to reliably replicate this, please file a bug report.
I have the same issue. Fresh new installation of KiCad 8.0.4 on Sonoma 14.6.1
Closing/reopening work if you add footprint on schematic.
This happens reliably.
But if you try to add footprint from a library directly to PCB the preview is blank. While 3D view is OK.
Appears to be fixed in 8.0.5
Thanks for update - I’ll give it a try.
