Footprint wizard hasn't available any Footprint Generator
I’ve installed Kicad this week in Windows and Linux(vs: Zorin OS(based on Ubuntu)) and in both the Footprint wizard has not available any Footprint pattern.
imagen
Kicad doesn’t let me write a path for the footprint generator files, and Python Modules are updated.
And when you search the footprint patterns in the Gitlab’s code doesn’t appear in the folder with the others components.
Then, I don’t know if it is a bug or I have to write the path of the footprint patterns.
Please, help
Hmm, that’s weird,
I get the same from ** Footprint Editor / File / Create Footprint**
The Update Python Modules button also does not seem to change a thing.
I’m running Linux mint and these are the footprint wizards and their locations as installed by KiCad.
paul@cezanne:/usr/share/kicad/scripting/plugins$ ls -hl
total 184K
-rwxr-xr-x 1 root root 1,9K Mar 21 18:21 arc_test.py
-rwxr-xr-x 1 root root 6,0K Mar 21 18:21 bga_wizard.py
-rwxr-xr-x 1 root root 5,1K Mar 21 18:21 circular_pad_array_wizard.py
-rwxr-xr-x 1 root root  28K Mar 21 18:21 FootprintWizardBase.py
-rwxr-xr-x 1 root root 6,6K Mar 21 18:21 FPC_wizard.py
-rwxr-xr-x 1 root root    1 Mar 21 18:21 __init__.py
-rwxr-xr-x 1 root root  25K Mar 21 18:21 kicad_qrcode.py
-rwxr-xr-x 1 root root 7,8K Mar 21 18:21 microMatch_connectors.py
-rwxr-xr-x 1 root root 4,7K Mar 21 18:21 mutualcap_button_wizard.py
-rwxr-xr-x 1 root root  14K Mar 21 18:21 PadArray.py
-rwxr-xr-x 1 root root 8,8K Mar 21 18:21 qfn_wizard.py
-rwxr-xr-x 1 root root 6,3K Mar 21 18:21 qfp_wizard.py
-rwxr-xr-x 1 root root 7,7K Mar 21 18:21 qrcode_footprint_wizard.py
-rwxr-xr-x 1 root root 8,8K Mar 21 18:21 sdip_wizard.py
-rwxr-xr-x 1 root root 7,6K Mar 21 18:21 touch_slider_wizard.py
-rwxr-xr-x 1 root root 6,1K Mar 21 18:21 uss39_barcode.py
-rwxr-xr-x 1 root root 6,7K Mar 21 18:21 zip_wizard.py
Application: KiCad Footprint Editor
Version: 6.0.4-6f826c9f35~116~ubuntu20.04.1, release build
	wxWidgets 3.0.4
Platform: Linux 5.13.0-27-generic x86_64, 64 bit, Little endian, wxGTK, xfce, x11
	Date: Mar 21 2022 17:21:29
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.81.0
	ngspice: 31
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
Interesting, same happens here, Linux KiCad 6.0.4.
But if you enter the footprint editor via the PCB editor, then the wizards are available. Sounds like a bug.
I wanted to open an issue for this on gitlab, and discovered it was already reported last week:
It turns out that it only happens if the PCB Editor has never been opened in the session. Once it has been opened, and even closed afterwards, the generators are available. Which is why the bug wasn’t noticed sooner.
