I just installed KiCad 8.0 on my Mac (Mac mini M1 and Sonoma 14.3.1) and started to design. When I’m going into the part/symbol library I can choose a part and a suitable footprint. The footprint is shown in the footprint preview window (bottom right).
When I’m in the schematic editor and choose “Run footprint assignment tool” from the menu and pick the desired part I can choose from the menu “View the selected footprint in footprint view” but end up with an empty black window (zoom in and zoom out doesn’t help). Btw the 3D view is working properly.
So what is happening here? Footprints are available but not in the footprint view. What can I do to solve this problem?
I also saw this once, but after rebuilding I couldn’t reproduce it. It appeared to be an RTTI failure in the debugger, but I have not idea what caused it (or what made it go away again).
You could try re-installing (or installing the 8.0.1RC2 that just came out).
I just upgraded from 7 to 8.0.1, and I am experiencing this same issue. I am attempting to update the connector on an existing design, but the footprint view is not there so I’m not able to place it on the PCB.
Here you can see the PCB editor has no footprint, but the 3D viewer is showing the part:
Thanks for your help. I updated to 8.01. Maybe I’m doing something wrong but when I open the footprint editor and select a random part I don’t see any footprint.
Just to make it a little bit clearer. When I want to select a part I can’t see a preview of the footprint. That is the same what I described above. Let’s call this KiCads global footprint viewer (This is the window where the overall parts list is on the left and the footprint preview in the middle).
But when I already have parts in my project and I open the footprint editor I can select a part from my list and I can now see the footprint (This is the window where the parts list is in the middle and the footprint window on the right).
ok, thank you. It seems I’d expected something which doesn’t exist.
I tried the hover function, it’s nice but what do I need it for when there is only a little black screen appearing next to a big black screen?
I could post screenshots here but I don’t know how to upload them.
From a Mac I don’t know . . . in Windows I use the Snipping tool, you can also upload a JPG or if you can get the screenshot on your clipboard you should be able to simply paste it into your message.
The big black window is ok (because you have no footprint loaded yet - look at the titlebar of the footprint editor).
The small hover preview window is not ok - this should show a preview of the hovered library item. Could be a apple specific bug.
