Thanks to this forum I recently discovered the net highlighting capability in version 6.0.
I think that button works pretty much as desired when I select a net on the schematic. One thing that happens is that the footprints and tracks (which are not on that net) are dimmed. So far so good.
But if I exit that function (lets say I now hit the top right button in the schematic toolbar to select items) the footprints and tracks do not return to normal brightness. I can perform a fair amount of editing without the brightness restoring to normal. Actually it also seems that the previously-highlighted nets tend to remain highlighted even after I perform other actions. But it seems that if I click on a power port in the schematic, that restores the brightness to normal.
I had not previously been using the net highlighting function so I do not know if this is a new modus operandi. Is it my brain that is dim or is this a minor bug?
Application: KiCad Schematic Editor (64-bit)
Version: (6.0.0-rc1-119-g126563c839), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19043), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Nov 22 2021 12:00:10
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
