Footprint text on mask layer not included in gerber output
I’ve got an issue with gerber generation. I have text for PN and and revision to be placed in exposed CU so the mask should be clear over it.
In PCBNew I have the following section of bottom CU
and mask
(Note edge cuts also included both times)
In the gerbers I get the following bottom Cu
and mask
which does not show the PN: and Rev: text
The gerber views are from gerbv but the kicad gerber viewer shows the same.
I’m assuming I’ve missed something in either the layout or gerber generation
So the text properties
and the plot settings
Any thoughts on what I may have missed?
Oh and Kicad Version
Application: kicad
Version: (5.1.0)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
I’d suggest finding those strings in the design file with a text editor, and comparing them.
If one works, and two do not, it’s then spot-the-difference.
Please report this bug at https://bugs.launchpad.net/kicad
The text items are being plotted as negatives (knock-outs), which are inverted by the layer.
–Edit–
Actually, I just noted that your version information is old, so I posted the bug with as seen in 5.1.4 so that we can address it.
Thanks @Seth_h, I take it there’s no workaround?
@PCB_Wiz, here’s the two text’s in different layers. AFAICT the only difference is the layer.
 (fp_text user PN: (at -20.955 -6.985 180) (layer B.Mask)
  (effects (font (size 2.54 2.54) (thickness 0.508)) (justify left mirror))
(fp_text user PN: (at -20.955 -6.985 180) (layer B.Cu)
Robert
My first glance had those as 3 strings, but I think the top text has sharp corners, so it must be shapes ?
so my suggestion thinking one worked, did not apply to all-text…
I think seth_h may be right
Perhaps there is a workaround.
There was an earlier thread about negative text, and someone did a gerber merge utlility that takes two gerber files and combines them as LPD / LPC (plot Dark / Plot Clear (inverted) )
Or, you could create a simple rectangle as your no-mask, for the text to show thru ?
@PCB_Wiz The gerber merge would be kind of hard to maintain since it would need re-applying on each generation. The rectangle is definitely trying.
Yep, the rectangle does indeed get plotted as expected to the gerber so that should work for this case. Might not work for everyone that runs into it but it’s sufficient for this particular instance of the problem.
Thanks
Robert
You can place the text on the board as a text item instead of inside the footprint. We’ll get this fixed for 5.1.5.
Yep, that seems to work. So two work arounds available.
