Hello
I’m unsure what to do in this case.
I have created a symbol and the corresponding footprint for an Adafruit GPS Module.
Usually this is a piggyback to an Adafruit Feather µController.
However, in my design I have the GPS module separated from the µC.
As marked in the attached picture, only a few of the pin’s are connected. The others have no function.
Now the problem is that the DRC brings error’s like “Warning: No net found for symbol U9 pin 8” and so on.
Simply turn off or change the severity seems to be a bad idea.
So I reach out to you, if someone have a solution for this. Or some kind of standard practise? I’ve been thinking about to delete the unused pins in the footprint and just replace them by a circle on the “Edge cuts” layer. But then I don’t have any copper there to solder the module down. It would just be fixed on the used pin’s. I think it would strong enough but I guess there is a better solution for this?
Best regards
Simon
