Footprint Library Browser, save windows and panel size/width
Or is this already possible? I found no obvious way. Only idea would be using some OS setting or tool…
Usually, I pull the window wider and larger to be able to read everything, but every time I close the Windows and open it back up again it resets to it’s default settings.
Application: KiCad
Version: (6.0.4), release build
	wxWidgets 3.0.5
	libcurl/7.82.0 OpenSSL/1.1.1n zlib/1.2.12 brotli/1.0.9 zstd/1.5.2 libidn2/2.3.2 libpsl/0.21.1 (+libidn2/2.3.0) libssh2/1.10.0 nghttp2/1.47.0
Platform: Linux 5.17.1-3-MANJARO x86_64, 64 bit, Little endian, wxGTK, KDE, x11
	Date: Mar 18 2022 08:05:28
	wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.24
	Boost: 1.78.0
	OCC: 7.5.3
	Curl: 7.82.0
	ngspice: 36
	Compiler: GCC 11.2.0 with C++ ABI 1016
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
size and position of the footprint library browser window is already saved (at least on windows 10), the width of the 3 columns not. If you want this feature for next christmas/birthday party: you need to register at gitlab and write a good description. use the command Kicad–>Help–>Report Bug, this will automatically open a correct gitlab-template (including the correct version-information). You can also mention the symbol-library-browser which already saves/restores not only the window size+position but also the actual column-width.
The weird thing is, that it remembers the dimensions now. No idea why now and not before, though. It waited until I prepared an issue.
