Footprint Library Browser button doesn't appear
Problem:
Footprint Library Browser button doesn’t appear and the text is gone
if I resize the window, the button appears but the text is not really readable.
Is there a way to fix this?
System:
Linux Mint Cinnamon 20.3
Kicad 6.0.6-3a73a75311~116~ubuntu20.04.1
wxWidgets 3.0.4Unicode and Boost 1.71.0
Platform Linux 5.4.0-122
Did you click on the books (the three stripes) at the end of the column with the description?
the 3 books are not there, I have to resize the window everytime, before the 3 books appear.
I found a screenrecording with the same issue
https://gitlab.com/kicad/code/kicad/uploads/29e079a0060afa2cab706dc6bd5fa01d/simplescreenrecorder-2020-10-20_16.40.21.mp4
Click on anywhere on the footprint line in the Value (Wert) column and the books should appear.
there is no problem with Windows or Manjaro
but if you look at my screenrecording, I just made,
you can see its only working if I resize the window
Has this problem just happened or has it always been so?
I use this version on Mint Cinnamon 20.4 and have never had a problem.
The only difference is I use the English version.
Application: KiCad
Version: 6.0.6-3a73a75311~116~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-122-generic x86_64, 64 bit, Little endian, wxGTK, cinnamon, x11
Date: Jun 20 2022 15:49:56
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.83.1
ngspice: 36
KICAD_USE_OCC=ON
KICAD_SPICE=ON
every thing the same
I changed all language settings to USA (Linux mint) and kicad to english.
Still the same problem on two different PCs (new AMD 5600G and an old intel xeon)
we just switched from windows to linux mint
there was no problem with windows or with manjaro (VM)
Application: KiCad
wxWidgets 3.0.4
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.83.1
ngspice: 36
KICAD_USE_OCC=ON
KICAD_SPICE=ON
it seems to be a problem with the linux mint theme
I changed the controls to Adwaita
thank you for your responses
Sorry for no response earlier, been out all day.
Glad the problem solved.
