Hi, I am fairly new to KiCad, working on my first board layout. I am using the Schurter 1301.9307 Pushbutton Switch and am looking for an appropriate footprint. Can anyone identify a footprint I could use either in the built in KiCad libraries or a library that is available for download?
This switch is very similar to most cheap tactile switches, there’s almost certainly a part that fits in the standard library - however, it’s also a very simple footprint, so it’d be a great chance to get some practice making footprints of your own…
Great! I think that one will work perfectly, the pads are spaced exactly the same as the drilling diagram in the datasheet.
On that note, is there a distance measurement tool built into the footprint viewer (that which is built into CvPCB) or a way to click on a pad and see it’s position? I had to open the actual footprint editor to get accurate measurements and I’d rather not do this every time if I don’t have to.
Yeah. Kinda annoying. I’m using stable and I couldn’t even find a way to change the grid so I’d have a reference. I don’t think it even alerts you to what grid is displayed if I remember correctly.
