@jmk
As explained in my reply to @paulvdh, I am trying to tie the “chassis” of the front PCB-based panel to the main PCB (which is perpendicular to it).
Also to tie the rear backplane panel “chassis” to the main PCB.
Of course, I could use a hole and add ground fill on the PCB after placing the bracket.
I am concerned about possible grounding issues.
The design is for a DC motor servo driver operating at 200V DC and up to 30 amps.
The ground of the 200V supply can be considered as “star ground”.
By “chassis” ground, I mean the ground of the PCB-based front and rear panels.
“Chassis” can also be considered as being the same as what could be referred to as “cabinet ground” of the industrial rack into which the unit slides.
There will be a dedicated external connection cable (from the machine system “earth” to the rear backplane panel “chassis”, whilst there may also be connections (of dubious electrical quality in relation to where the front panel seats against the metal racking at the top and bottom of the 6U module (assuming I provide copper in the areas - whether or not I should do is an open topic).
Of course, the front PCB needs to connect back to “earth” from a safety (and possibly also a shielding) perspective.
The machine system “earth” cable will connect to “chassis” ground via the rear PCB-based backplane.
In relation to the brackets, they provide the link from the front PCB-based panel to the main PCB.
The large pads associated with each of the two brackets (to be located near the top and bottom of the front panel) will be connected together on the main PCB and be routed in some way back as a single connection to the “star ground”.
Probably, I should only connect “chassis” to “star ground” at a single point, i.e., where the motor sinks its current?
From that “star ground” there will be other grounds radiating outwards, such as that for the 3.3V digital supply.
Possibly the main ground plane of the PCB will be such that it only connects to “star ground” at a single point (as for “chassis”)?
In other words, “chassis” ground will not be the main ground of the PCB but instead be simply routed back to the “star ground” point.
Those are my thoughts at the present time … !
The photo illustrates the general format of the product - this is an old analogue-based servo driver and I am attempting to achieve the same functionality for a new digital-based version.
