Hi BlackCoffee,
The transparency is now really good, the digit and the electrodes are visible very well. The improved glass look makes it now more like a Nixie tube. You have done a great job. Thanks.
If I may make one comment though, The way, the tube sits on the socket (used in this model) now, the socket will have to be mounted horizontally on the PCB in order to be able to read the digits properly This would mean that the tubes cannot be placed close enough to each other. They will always be separated at least by the distance taken by two mounting holes between them on the PCB.
I think this is because relative to the tube pin (numbering) and its mounting, the digit orientation is off by 90 degrees. So, if you have time and if you feel like doing it, please rotate the digit by 90 degrees anti-clockwise from what it is now. This way, the digit and the socket mounting holes would be in line (for vertically oriented socket mounting holes).
Further, as you know there may be many socket options (i.e. with and without mounting holes or even simply single-socket pins) to mount this tube and you cannot possibly make a model for each socket + tube combination. Thus it might be best just to orientate the digit correctly w.r.t. tube pin (ref. ZM1022 tube drawing) and simply drop the socket off from your current model. This way your tube model can be used universally and if needed, the user will create its own socket model as per their choice.
This is just a friendly suggestion you might want to consider.
Thanks again and best regards
