When I tryed to open Footprint Editor, it takes HOURS to load. I have to cancel it.
This was happened in the 5.1.9 version installed via apt in Debian.
Now I tried 7.0.1 with flatpak hopping this get solved, but still happen so is something of my computer. I’ve tryed to uninstal and reinstall many times.
That’s an unusual output that I’ve never seen before. It looks like it is running in some sort of debugger or profiler. Since this happens with two very different versions, it sounds like you might have a unique setup with your operating system or hard disks.
I’ve tryed to install xapp and is installed, I don’t know why the error.
I don’t know if other application is searching something somewere. But its the only time I saw this.
It start When I open the PCB editor or the Footprint Editor, and after 2 hours, when it reach *** 1999 *** the editor open and works correctly.
I tryed all solutions in the post and the message still showing.
UPDATE:
After several attempts, I left it to see how long it took.
I finish after 2 hours. When I finished I was able to use the footprint editor and the PCB editor correctly.
As long as I didn’t close the program, I was able to use it correctly. Once I closed everything and reopened it, again I had to leave it for 2 hours until I could use it.
I don’t know if it has something to do with it, but the fp-info-cache file weighs more than 3MB.
Kicad comes loaded with enough Footprints, STEP and WRL files to choke a horse. Many users don’t need most of them for most projects so, simply Un-select those not needed and they won’t load - thus, saving time. User can always re-enable them…
Most likely this won’t apply but, worth mentioning it…
I’m using v6 (won’t upgrade for at least six months until 60% of Bug’s are dead).
In earlier versions, one of the Paths pointed to Git-Hub and if/when not able to access that site, Kicad footprint loading took all day and never completed. I deleted that Path and all worked well…
This is not your direct problem, but the KiCad footprint library system of one file per footprint, suffers badly on spinning disk hard drives that have directory fragmentation and therefore slow file seek
