I’m pretty sure that, in V5, when a text was tagged invisible, it was impossible then to click on it and to select it, both in Footprint Editor and in PCBnew.
However, in V6.0.2, I found that invisible tagged Front Silkscreen text (for instance, Value field) is still selectable by left click.
This is confusing because, you left-click on a visible element, and “something else” is selected instead.
At first I thought that my footprint was corrupted in some way, but I figured out later that I was clicking on the invisible Value text field…
Is this expected?
Is it a bug that I should report?
Basically all items that are displayed can be selected (unless filtered). In the Appearance Manager Objects tab you can select whether hidden (invisible) text should be displayed, or not.
