Footprint does not function
Hi there!
I was using Eagle since many years and then i installed KiCad. There is a problem with my installation.
When i draw a schematic the ic’s do not show the footprint on the layout screen. What am I doing wrong?
Sadly, you are mistaken in your belief that KiCad will behave like Eagle, or in fact any other ECAD system. You should work through the tutorial to understand the workflow:
In addition to retiredfeline’s good advice above . . . to get you on the right track have a look here:
Yes it looks like the same link as above but this one takes you to a more relevant section relating to your specific question.
