Hi guys,
I’m needing this footprint: http://www.molex.com/molex/products/datasheet.jsp?part=active/0436500500_PCB_HEADERS.xml but i can’t find it in github or other network repositories.
Do you know where I can find it?
Hi guys,
Well make your own?
It’s not as hard as you might think.
If you want to share the footprint with others via the official repo, make sure you follow the klc
Also remember that most connector footprints are script generated. It might pay to have a look at that.
I didn’t find a KiCad version, but I found Eagle version here http://www.diymodules.org/eagle-show-object?type=usr&id=2259&file=con-molex-micro-fit-3_0.lbr&package=43650-0500. Eagle libraries can be loaded directly by KiCad, but the silkscreen outline appears to be missing.
I converted the Eagle library to native Kicad, which produced a better result. This is an automated conversion, so may contain errors. It also retains some quirks of Eagle, so pins are numbered P$1 etc. You can renumber them or use the included symbols.
con-molex-micro-fit-3_0.zip (238.7 KB)
Nossa man, muito obrigado, você realmente me ajudou muito. Era exatamente isso que eu queria. Thank you.
