Hi, new to KiCAD, just started using it to design a side project based on Artix 7 XC7A200T FBG484, I have been able to find the schematic symbol file, but wonder where i can find the footprint and 3d model file for it? or is there similar ones i can use as reference?
Thanks.
This in’t a footprint or 3d model, but the layout doc - page 269: https://www.xilinx.com/support/documentation/user_guides/ug475_7Series_Pkg_Pinout.pdf
Hi thanks. I am just curious if there are models made readily available, if not I will refer to the document and start from scratch.
Someone might have a good reference to FCBGA packages like that, if not you could use the BGA-484_22x22_23.0x23.0mm_Pitch1.0mm package in the Housings_BGA library as a good starting point. Sorry that still doesn’t give you a 3D model.
you can have a look at this repo for 3d scripting modeling
FCAD_script_generator/BGA_packages
what is already available can be found here
kicad-packages3D/tree/master/Package_BGA.3dshapes
BGA-484_23.0x23.0mm_Layout22x22_P1.0mm.wrl
Thanks all for the good info!
