Why does the copper pour not fill on pad#5. The labels are named correctly.
Deleting the graphics layer forming the custom shape solved the problem but would that be problem latter ?
Open the pad properties and set the zone connection setting to solid instead of thermal.
That is meant for pads not graphics polygon.
make a pad out of your polygon. (select the polygon and a pad that is inside it -> right click -> make pad from selected shapes)
Thanks that was easy.
BTW, for future reference at least on v5. Thermal reliefs don’t work on custom pad shapes like you just made. You would either need to do what you did by making the pad have a solid connection to zones, or manually draw in thermal reliefs with traces.
