Floating Wire Warning in ERC
I just received my non-functional PCBs in the mail today. After some investigation, I realized that I have a rather-overt mistake on my part in which a wire is floating and not connected to where it should. As usual, it baffles me how I could make such a mistake.
It seems that the ERC is mostly concerned with pins. That makes sense…to a point. The only flaw in this is that ERC is happy as long as the pin is connected to one other node…even if more nodes are required. I certainly don’t expect Kicad to read my mind when drawing the schematic, but it would be nice if it could tell me if I had inadvertently moved a wire in the schematic.
Is there a way to set the ERC in Kicad to give a warning for any unconnected, floating wires?
Thanks,
Brandon
There isn’t. Please feel free to submit a wishlist for ERC errors based on wires unconnected at both ends.
We can’t raise ERC for wires that are unconnected at one end as this is a common design as long as pins are connected.
Might no rise to the level of error but a warning might be merited.
An error/warning if 2 ends of a wire are disconnected would be a start.
Can you give an example of when a pin is intentionally connected to a wire within the Kicad schematic and that wire is left floating on the other end? I’m afraid my lack of experience or imagination is limiting me here. I generally strive to make sure none of the green, unconnected boxes exist by the end of a design but I’m always winging it by that point.
Brandon
Look in the KiCad demos folder for the video project.
Edge connector fingers?
Here’s an example showing a simple schematic as intended by the designer, and four ways to draw it incorrectly. Note that two faulty representations already have unconnected wire ends terminated in the small, green squares.
Which cases do you think should trigger an ERC message?
Dale
Case 0 should check out provided pin definitions are correct (i.e. no I/O collisions etc.)
By running an ERC case2 actually becomes case 1 since the Kicad automatically removes dots with only two connections.
After that the rest is a philosophical matter. How is any given system to assume what is meant in case 1. A rather complex analysis could be deployed to make some guesses. Tricky stuff here.
Case 3/4 should definitely raise at least two warnings. Unconnceted wire, and a loose wire end.
This is just silly to the point of being ridiculous.
This is what most of us think is an unconnected open ended wire:
This is what is in the KiCad demos folder video project:
NOTE: I have moved /PCWR but left /PCRD exactly as before.
Next, I moved it to the “end of the line”:
Hey, I think I just now have a great idea! Lets put 50mil junction dots everywhere a label is connected to green line? Should I file a bug report for this missing junction dot?
ON EDIT: What might that look like?
COOL! And, it passes ERC!
I’m sorry but I don’t quite understand this post. Are you venting?
No.
Simply speculating where this will go once certain others figure out that the junction dots are missing from labels…
Same as before with the Bug Report that I believe actually fixed this issue:
I’m fairly certain that KiCad now/currently adds junction dots to junctions with only two connections, where it did not before. Along with that change, was the change to force the size of the junction dots to minimum that that was a percentage larger than the wire width.
@Seth_h I thank you very much for the one fix I have been waiting so long for; getting rid of needless Junction Dots. I only fear that history will repeat itself and I’ll have very many big green dots in my schematic again only a short time in the future.
Aha, I see. That’s what it is. The dot gets removed in ‘dirty’ as in master.
The current 5.1.2 does indeed keep that two wire dot. Bummer.
There might be chance that the upcoming 5.1.3 already removes that two wire dot.
Kind of getting ‘spoiled’ ever more working with ‘master’. :sunglasses:
Hm i can not reproduce it by removing a wire in such a case (the expected way to reach that state)
Or did you mean a manually added junction is not removed by ERC? (I doubt ERC is meant to do that but could be a side effect of recalculating the schematic.)
5.1.2: I placed a dot on any 90 degree wire path. A follow up ERC run does not remove it.
While as of master ‘Version: (5.1.0-1348-g3514473a5-dirty), release build’ an ERC run removes the dot every time, and so it should methinks.
For me, junction dots are an essential information. They signal exactly what they are named after.
So case 2 is an error. There is no junction, so the dots were placed there with a different goal that doesn’t make sense.
Case 3 is an error, because the signal ends nowhere, but why is there a line? User has to correct that.
Case 4 is an error. A signal line without any signal has no purpose.
We sometimes do have brain farts, and I really like it if the CAD at least catches a few of them.
It has to be clear, precise and strict with the rules.
I see no reason to place junction dots or dead end lines on a schematic. It only confuses others and after a few years even you.
Nick
Case 2 can not “naturally” ocour in current kicad versions. Meaning it was delibriatly constructed using the add junction tool. Maybe the add junction tool could ask if one really wants to do such a thing. (Removal at erc run seems more like treading symptoms instead of dealing with the real problem. )
Be carefull when ranting about junction dots.
It is apparently a religious topic and it might get this thread blocked.
From an electically consistent point of view it shouldn’t even be possible to place a junction dot on less than three wires.
If someone want’s a dot, an ordinary graphic primitive will do.
That’s OK!
But why was it added deliberately? Makes no sense, possibly was a mishap, user was interrupted by $whatever. So this should generate an error.
Automatically removing it during DRC doesn’t seem to be good to me. There is a reason why the dot was there in the first place.
Nick
I don’t understand at all why junction dots are manual. They should be fully automatic: they are in every junction and nowhere else, or just nowhere (depending on preferences). And of course not in pin/wire or label/wire etc. connection points. They should be a visual feature of wire/wire junction.
