Hello, I’m running Linux Mint 20.1 Cinnamon. I was using Kicad 5 for a long time until I tried upgrading. My system is really messed up now. How can I get back to V5?
Yes, I know Linux Mint is not supported, but it works fine with the Ubuntu install and V5. I want to upgrade this system shortly, but I’ve got a few projects I want to sort out first.
I clicked on LM on the download page and there was a warning that it isn’t supported. I downloaded Flatpak and installed 6.0.4 through it. I just tried updating it to KiCad 6.0.7 and it won’t let me… it says the current installed version is stable.
Examples load ok in Kicad 6.0.4, but it still seems broken. I get massive errors and it shuts down when trying to open any project from V5. I’m not comfortable starting a new project with it.
It still says 6.0.4 in the About-> Help tab after trying everything.
I just want to load some old projects. It won’t let me load old project files. PCB files load OK in stand alone mode. Schematics give me an error in stand alone mode. When trying to load, I get a warning flash “The project symbol library cache file was not found.” I tried pointing to it and no luck. I tried putting it in a temp directory and no luck. Setting up library paths always messed me up in V5. Without the library, I get question marks everywhere. Here’s the kicker… If I browse symbol libraries, I can see all of my stuff and manually load every symbol…
Are versions 5 and 6 not friendly with each other? Should I install V5 next to V6?
I uninstalled the Flatpak install and installed 6.0.7 Ubuntu KiCad PPA referenced above. I haven’t found any issues yet and my old projects load just fine.
You will now find any updates will appear in your Update Manager… eg 6.0.8 when it exists.
Note: 6.99 (the future 7), is broken in Ubuntu at the moment, so don’t bother trying to experiment with it.
Note the changes in the Schematic.
After saving a 5 project in 6, that project will not open properly again in 5, so it is worth keeping backups in 5 at least 'till you’re happy and confident with 6.
