Just wanted to document this: I have built eeshow
according to Building eeshow on Ubuntu 14.04. Then I had a problem - no matter what project I opened, I couldn’t get symbols found in libraries; pretty much every symbol referenced in schematic resulted with e.g. "device:LED" not found
and so on.
First of all, the KiCad version I use (which produced the projects) is:
Application: kicad
Version: (2017-11-13 revision d98fc85)-master, release build
wxWidgets 3.0.2
libcurl/7.35.0 OpenSSL/1.0.1f zlib/1.2.8 libidn/1.28 librtmp/2.3
Platform: Linux 4.4.0-109-generic i686, 32 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.54.0
Curl: 7.35.0
Compiler: GCC 4.8.4 with C++ ABI 1002
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=OFF
KICAD_SPICE=OFF
So, by comparing http://neo900.org/git/ee
projects with mine, I found that:
- The
.pro
project file generated by this version of KiCad does not create a[eeschema/libraries]
section, which is what is apparently used byeeshow
to determine libraries - The
eeshow
code does not take into account symbol names prefixed by the library with a colon, such asdevice:LED
Regarding 1), I had to manually add lines for the [eeschema/libraries]
in the .pro
file:
[cvpcb]
version=1
NetIExt=net
[eeschema]
version=1
LibDir=
LibName1=myproject-cache
LibName2=/path/to/kicad/usr/local/share/kicad/library/device.lib
I have to refer both the -cache.lib
, and since I run KiCad from an external folder (that is, “portable”, as KiCad is not installed in system locations), I have to have a full path reference to that device.lib
as well.
For the second problem, a hack is required where the entire symbol name is split at colon :
, and then that is used for the comparison - it can be found in the patch file below (which also contains extra print statements for debugging, which you’ll probably want to comment):
diff --git a/file/file.c b/file/file.c
index 4690ebc..248e5f5 100644
--- a/file/file.c
+++ b/file/file.c
@@ -293,6 +293,7 @@ bool file_read(struct file *file,
char *nl;
+ error(" file_read: %s", file->name);
if (file->vcs)
return vcs_read(file->vcs, file, parse, user);
while (getline(&getline_buf, &getline_n, file->file) > 0) {
diff --git a/gui/gui.c b/gui/gui.c
index 834bd74..e5b5b76 100644
--- a/gui/gui.c
+++ b/gui/gui.c
@@ -285,6 +285,7 @@ static const struct sheet *parse_files(struct gui_hist *hist,
leader = &sch_file;
struct file lib_files[fn->n_libs];
+ error(" parse_files: n_libs: %d", fn->n_libs);
lib_init(&hist->lib);
libs_open = 0;
diff --git a/kicad/ext.c b/kicad/ext.c
index 13f244d..36c2357 100644
--- a/kicad/ext.c
+++ b/kicad/ext.c
@@ -63,6 +63,7 @@ static void do_classify_files_ab(struct file_names *a, struct file_names *b,
fn = a;
for (i = 0; i != n_args; i++) {
+ error(" do_classify_files_ab: %d %s", i, args[i]);
ext = identify(args[i]);
switch (ext) {
case ext_unknown:
diff --git a/kicad/lib-parse.c b/kicad/lib-parse.c
index 38f4a1b..20c40d3 100644
--- a/kicad/lib-parse.c
+++ b/kicad/lib-parse.c
@@ -396,6 +396,7 @@ bool lib_parse(struct lib *lib, const char *name, const struct file *related)
static bool do_find_file(struct file *file, const char *name,
const struct file_names *fn, const struct file *related)
+ error(" do_find_file %s", name);
if (file_open(file, name, related))
return 1;
if (file_search(file, name, fn->search, fn->n_search, related))
diff --git a/kicad/lib-render.c b/kicad/lib-render.c
index 17e6c78..f732bd5 100644
--- a/kicad/lib-render.c
+++ b/kicad/lib-render.c
@@ -716,12 +716,25 @@ const struct comp *lib_find(const struct lib *lib, const char *name)
const struct comp *comp;
const struct comp_alias *alias;
+ error(" lib_find name %s comps %p", name, lib->comps);
for (comp = lib->comps; comp; comp = comp->next) {
+ error(" lib_find comp: '%s' '%s'", comp->name, name);
if (!strcmp(comp->name, name))
return comp;
- for (alias = comp->aliases; alias; alias = alias->next)
+ // try without the : (for comparison 'LED' 'device:LED')
+ char *name_no_colon = strrchr(name, ':');
+ if (name_no_colon != NULL) {
+ name_no_colon++; // we want to look at what's _after_ the ':'
+ error(" lib_find comp no colon: '%s' '%s'", comp->name, name_no_colon);
+ if (!strcmp(comp->name, name_no_colon))
+ return comp;
+ error(" lib_find comp->aliases %p", comp->aliases);
+ for (alias = comp->aliases; alias; alias = alias->next) {
+ error(" lib_find alias: '%s' '%s'", alias->name, name);
if (!strcmp(alias->name, name))
return comp;
error("\"%s\" not found", name);
return NULL;
Well, that helped me finally open my schematic projects in eeshow
- now just to find the similar facilities to export PCB to PDF from the command line.
