Finished first kicad layout, please check my work
Hey everyone, I just finished my first board in kicad and I’m getting ready to send it to a fab shop. Will someone check the layout for obvious mistakes. I know a few points I could improve but I think this will suffice.
It’s a 1 sq.in layout w an RF transceiver, motor controller, and mcu. I’ll put everything including code for the microcontroller on git once the circuit is working.
Here is a link since I can’t upload yet:
https://drive.google.com/open?id=0Bz3IuPUoatVdclhORWZTbVhQbTg
A few observations:
  • You use 5mil tracks, which seems unusually (maybe even unnecessarily) narrow.
  • The via dims seem to be off, especially since you use via-in-pad. Typical would be sth. like 25/13.
Thank you. I doubled the track width (0.254 mm) and reduced via sizes to (0.7mm/0.35mm), next layout will use standard sizes.
*edits were made on windows which made the files unable to be opened on my ubuntu box (still trying to compile a more recent kicad from source w not much luck)
Link:
https://drive.google.com/file/d/0Bz3IuPUoatVdYXB5bHRNd1cydlE
Looks much nicer (works with linux here [bzr 5398]).
There are a few warnings about unconnected pads though.
Moved to the Projects category
