is it possible to rotate groups by an arbitrary angle.? I do not find such resource.
THX
Cheers
Detlef
THX
Cheers
Detlef
I am using software 5.1.6 so things might be different.
Under board layout, Preferences, Preferences, Pcbnew, Rotation angle: (change from 90 to 10). Now every time you “R” the area or object will rotate 10 degrees not 90. I think you can put almost any number there. I did a board where each block needs to be at 18 degrees rotated.
Yes, that worked under 5.1.6.
Thank you
Cheers
Detlef
Right click and select “Move Exactly…” (or use the keyboard shortcut ctrl+m). You can rotate objects with a resolution of 0.1 °. (Works in 5.1.10, but features are only added between major versions, so it should exist in 5.1.9 too.)
