In the schema I hit “E” on keyboard to edit the symbols values.
I put a path to a PDF in “Datasheet” like “./pdf/bq32002.pdf” where “./pdf/” is the relative path from the schema.
But when I then hid “D” to open the documentation file it is not found. Is there any other way to state where documentation is located if they are local?
