Find all global labels that have only one instance?
I’m reviewing a multi page schematic. When I find a global label label with only one instance, it is usually a mistake. Right now, I hunt these down by clicking on the label, then CTL F multiple times to see all instances. KiCad will go through all schematic pages finding instances. Is there a way to flag all cases of single-instance global labels? All I see in the Schematic Setup menu is “label not connected to anything” which is not quite what I want.
One line lower there is: Global label not connected anywhere else in the schematic
Also, do note that if both a global and a local label with the same name are used on the same page, they do connect to each other.
Thank you. That’s exactly what I need.
Only recently I found out that the schematic editor has Net Navigator. Enable it from the View menu. Then highlight the label/net. It’s really helpful when the label is used in several sheets, but also shows if it’s only in one.
