I am designing a 2 layer PCB and i have setup the both layers as signal …
i have finished my signal routing, now i am trying to make VCC on top layer and GND on bottom layer.
on my board there are 90 , 2x3 header SMD connectors on pcb, 1st pin of each connector pin is VCC , now i am connecting this pins using FILLED ZONES , it is happening but when i run the DRC , it trough’s the error as UNCONNECTED PADS same with GND layer also
This is not what I meant.
You need to edit the zone parameters and assign a net. This is not done automatically.
Point to a zone edge. Hit “E”. Clarify to select your zone, and in the dialogue you can select the approriate net.
