i create 2 different PCBs with filled areas, one PCB shows like pic1, the other PCB shows the areas like pic2. How can i set that both PCBs show the same outlook?
best regards rené
best regards rené
The difference is most probably a different setting for zone transparency. Look into the right side appearance panel, and there into the objects tab.
sidenote: always mention the used kicad version.
Hallo,
thank you so much, its a slider for the right setting
I search some hours and did not find a Solution…
regards ré
