Fill Zone Incorrect
Hi
I have a 5V voltage regulator and have placed a fill zone around the 5V output and have connected it to 5V net. When placing a GND fill zone on the same plane the 5V fill zone does not show up as if it is part of the GND fill zone. What am I doing wrong?
I’m having a little trouble following but I think you need to raise the zone priority of the 5V fill so it doesn’t get incorporated into the GND fill. Click on the zone outline and you should get a menu option to edit the zone properties.
This FAQ helps to illustrate hermit’s remark:
Thank you very much for the replies. Priority solved my problem.
