I had a PCB with a fiducial which has been outside the board edge after importing a new board shape from the mechanical CAD for the case.
I’m wondering about the DRC did not flag the copper being outside the board contour. The PCB manufacturer’s checks reportet “parameter error”. I can’t find any parameter in the design rules severity setup which might be related to this.
I have done a minimal project to verify, please find attached. Think this should be considered to be a bug in the DRC (although not high priority). KiCAD_Fiducial.zip (5.8 KB)
Thanks to the development team to deal with that in an upcoming bug fix.
Roland
I read and interpret your post the following way: you want a DRC-check: “copper outside from board-outline”
such a check is currently not implemented (so no bug, but a missing feature)
I could imagine that this check could be useful in some circumstances - so in principle this seems a reasonable request
so if you are really interested in this drc-check you should open a new gitlab-issue (as feature-request)
describe exactly the wanted feature
and for a requested new drc-check add an example-project which contains false elements (in this case: copper outside board) so that the developers can easily check the new algorithm
@RolandE : If you use the kicad-builtin bugreport (every kicad-application–>Help–>Report bug) than you get a prefilled template which already contains the section-headers and the version-information (with quotation-marks to indicate a source-code section) so the gitlab-bot doesn’t close your issue immediately.
Thanks for this tip. I deleted too much of the template in my first attempt as I did not figure out it is automatically parsed (and require the tags to be recognised). I thought the instructions are just a hint to get anything into the request.
As the initial issue has been closed by the bot I have done another. So there will be two identical requests now, as you re-opened this.
