I did not know about multi-part schematic symbol before, therefore I crated 8 separated symbols. Is it exist any way to edit it in one symbol with 8 different units without re-creation each of it manually. And without using scripts.
Its custom symbol for BGA, so its a lot of pins there.
Is it what I need? [solved] Import component in multiple unit component
If I remember correctly mulit-part units are created with a letter appended. I’m not sure if you do U1a, U1b, etc. if that will let you assign everything to one footprint but it might be worth a try. If not then you might be able to do a multi-part symbol and import what you already have.
