Fabrication tool kit generate old version of Gerber's and BOM
When I hit the generate button, the output does not reflect changes in the current project. I get the fits version of the gerbers nad BOM. If I use fabrication output, form the file menu in the PCB editor, I dio get the correct latest version gerber.
What I am I do in wrong?
Did you try saving the PCB layout to file with Ctrl-S before running the plugin?
Yes the project has been saved. I have tried multiple things even saving the project under a new name and I still get the old gerbers and BOM
Your Gerbers and BOM files have todays date ? can you check please . . .
NO they are the old BOM’s and gerbers. WTF? I am looking in the production directory.
Is it related to this: BOM and position files are not created in V4.3.0 if checkbox is not pressed. · Issue #158 · bennymeg/Fabrication-Toolkit · GitHub
What version of the Plugin are you using ?
Could it be that you are looking at an old set of fab files and that the output is to a different directory?
the creation date on the directory structure was yesterday (much newer than the file date) . Im must have moved the old files.
this is my issue. I was in the wrong directory. there is a project/production directory and a project/jlcpcc/production. Thanks for making me look. please close it.
