Is there a way to extract schematic, layout and 3d view from command line?
I use GIT, and I would like to automatically extract those images, to make reviewing pull requests much easier.
I had pictures like this in mind:
Thank you!!
Thank you!!
At the moment KiCad does not have a good command line interface yet.
Maybe you can do something with feeding it keystrokes from some script.
Thank you very much!
Do you know if there is a way to print via cmdline? … I could print to PDF or an image printer
Thanks!
You might find these projects useful.
KiBot can be triggered to process outputs following commits and works in a CI workflow
Kiri is a combination of two older projects which allows comparisons between the schematics and layouts of arbitrary commits
You could also probably script this to produce some nice composites for documentation.
Thanks a lot!! I will take a look at those projects
