Extra pin causes “Warning: Pad missing net given by schematic”
I have a part with four electrical connections and a package with five connections. One pad is supposed to be unconnected. I created a footprint with five connections and a symbol with five connections and set the unconnected pin electrical type in the symbol to “Unconnected”.
However, when running a DRC check the PCBEditor complains “Warning: Pad missing net given by schematic”. Why does the DRC complain about a missing net on an ”Electrical Type: unconnected” pad?
Version: 6.0.4+dfsg-1~bpo11+1, release build
Your workflow/approach sounds good, I can’t see a clear mistake. Can you upload a (possible stripped-down) the archived zip-file of the project?
That’s reassuring that it’s supposed to work. If I place only that component in a single file it works without the DRC warning, which is strange. I’m investigating.
I recreated the board and the issue does not appear any longer. Same footprint, same symbol. Weird.
