I have been playing a lot with Pcbnew lately, and I noticed that STEP export works (yay!), but only if each component’s STEP file is included in its footprint (".kicad_mod" or “Footprint properties/3D settings”).
However, while STEP models are included for many components in the kicad-library Ubuntu package, the footprints files only refer to the wrl file.
We are currently discussing how this should be handled, I believe the approach will be the same as Stepup.
Options you can consider if you need to export a step file:
Use stepup to export the step model
2.open your kicad_pcb file in a text editor and do a search and replace for .wrl - > .step
please have a look at StepUp to convert a kicad pcb board and parts to STEP, when the models are just .wrl (or even .step)
StepUp will substitute .wrl to .step automatically and the result will be a fully STEP model of you kicad pcb
with the uptodate libraries you will just need to configure your KISYS3DMOD variable
PS models cannot include STEP by default because of compatibility with kicad stable release… using StepUp approach you will not need to change anything and your 3D viewer will use all the Material properties for better rendering
I understand now! I will also have a look at StepUp, thanks.
I guess the gist of my question is: is using STEP files as 3D models better in every way, or are there downsides?
If there are no downsides, I see several ways KiCad could handle this (which you guys have probably contemplated already):
Checkbox in preferences to replace WRL models with their STEP equivalent on the fly, if they exist
Removing redundant WRL files in a post-build script of “kicad-library”, and replacing them with STEP files in the kicad_mod files automatically, where applicable
Step has down sides, WRL has material properties meaning how it shines back and what not. If you search for “kicad Raytracing” you’ll see what it can do quite amazing wrl and step are for different purposes but both can be really useful.
Step is mainly a mechanical model, wrl is instead mainly a rendering model.
As @Shack has already pointed out, with wrl you can put Materials properties to your 3D model… then your rendering will be much more realistic in kicad.
One other big value is that wrl can have transparency on Materials and models… Transparency is really useful for many purposes, particularly when you need to check enclosures and also for nice rendering result.
