Exporting Populated PCB from KICAD into Fusion 360
I’m working on a project these days, a product which require enclosure around. this requires CAD modeling and i’m urgently looking for a solution to get the populated pcb into the 3D modeling platform.
Could some one please help me with this.
All I want is to get imported step editable file into fusion 360. does anyone knows a solid answer, please share .
Thank you.
Use .step models in all your footprints. Export boars to .step.
Thats it.
Nighties 3d support may work better for your needs
Thanks ,
could you please tell me steps to export PCB with components. once 3D shapes are created.
only available options are export as VRML, Idfv3 format. and 3 othr formats
freecad plus stepup (assuming you have your components in step format)
This is a freecad extension. It then populates the pcb with the components it has step files for.
