Is there a way to extract just the outline of the polygon that is created when you do a pour?
I can export to dxf the entire layer but then I have to delete all the tracks, footprints and other stuff.
As a quick test I just created a simple copper zone:
Then selected it, copied it, and pasted it in a text editor, and the result looks like:
(zone (net 35) (net_name "+5V") (layer "F.Cu") (tstamp 260e7c1c-5b26-4c11-bb61-6fcae20c7bf2) (hatch edge 0.508)
(connect_pads (clearance 0.3))
(min_thickness 0.254)
(fill (thermal_gap 0.508) (thermal_bridge_width 0.508))
(polygon
(pts
(xy 5.009728 6.455642)
(xy -4.690272 6.355642)
(xy -4.090272 0.255642)
(xy 5.509728 -0.344358)
In a “real” application it would be a bit more complicated then this. The copy & Paste operation also pasted all layer names and all net names into the text file, but I did not post those here.
If there is any sort of cutout (such as for via’s or pads) in the zone, then KiCad creates a lot of internal geometry for the zone.
The pasted text is in the form of an S-expression, and this is a fairly common data format and I suppose most scripting languages have a library for handling this format.
currently not directly as dxf.
workaround (assumed the zone is on top-copper layer):
- make sure board is complete, refill the zone a last time, save board
- CTRL+A to select all items on the board
- with Shift+CTRL+LMB-click remove the zone in question from the selection
- Delete all items, only the unselected zone remains
- File–>Plot -->DXF , with only Top-copper-layer enabled.
You get a question “zone fill not up-to-date – refilling?”. click “NO” to get the shape of the old copper-pour. - close board editor and than reopen board-editor (to get rid of the delete-action)
This results in a dxf-file with the complete copper-pour, without additional pads+tracks.
Thanks, that will work for me, don’t have to do it very often so don’t need to automate it.
