Exporting footprint from Freecad to KiCad
Would anyone know how i can export a sketch to KiCad as a footprint ?
Application: KiCad
Version: (5.1.6)-1, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Wurth_7443640150B.FCStd (6.2 KB)
kicad stepup plugin: Kicad StepUp: The Sketcher for Footprint generation
For anyone not having FreeCAD installed, here is a screenshot of the thing:
And indeed, this looks like a job for StepUp:
FreeCAD / Tools / Addon Manager / Workbenches / kicadStepUpMod
For me it seems a little stupid to set pad dimension to 5,59mm. I think someone there (at Wurth) got the task to rewrite recommended footprint from mils to mm (220mils = 5,588mm).
I suppose the author of original didn’t even considered 215 so consiedered 210/220/230 so the step of 0,25mm and now someone writes it with 0.01mm precision :slight_smile:
I would do that footprint in KiCad and certainly this dimension in my footprint would be 5.6mm.
I like that from Wurth I can get 3D models of used elements.
perfect ! thank you all.
All the measurements look a bit “weird” (such as for example 10.51mm)
After thinking about it for a bit. It may have been that the footprint was drawn from a photograph of a part and there was simply no effort whatsowever to “round” the numbers, and just left to whatever dimension was first drawn with the mouse.
