Export STEP file including all copper layers
I am using
Version: 8.0.6, release build
	wxWidgets 3.2.6
	FreeType 2.13.3
	HarfBuzz 9.0.0
	FontConfig 2.15.0
	libcurl/8.10.1 OpenSSL/3.3.2 zlib/1.3.1 libidn2/2.3.7 libpsl/0.21.5 nghttp2/1.63.0
Platform: Freedesktop SDK 24.08 (Flatpak runtime), 64 bit, Little endian, wxGTK, X11, gnome, wayland
OpenGL: Intel, Mesa Intel(R) UHD Graphics (TGL GT1), 4.6 (Compatibility Profile) Mesa 24.2.5 (git-3b9fcb7e4d)
	Date: Oct 14 2024 22:25:13
	wxWidgets: 3.2.6 (wchar_t,wx containers) GTK+ 3.24
	Boost: 1.86.0
	OCC: 7.8.1
	Curl: 8.10.1
	ngspice: 43
	Compiler: GCC 14.2.0 with C++ ABI 1019
and want to export the 3D model of the PCB including all copper layers, vias and tracks, as it is needed for post-layout simulation. I created a dummy PCB from scratch with 6 layers to test if this works:
and I am exporting it using “File→Export→STEP” with the following settings:
When I open this in FreeCAD I obtain this:
As you can see, all the inner layers are missing. Moreover, the blind vias were exported as regular vias.
Is this kind of export possible? I tried to use these settings but the dialog is different in my version of KiCad.
This is supported in nightly (8.99) versions.
Thanks for the info. Is it known when will it be available in stable version?
Probably early next year.
8.99 should become stable 9.0 at around Feb 2025. Major features are not backported to 8.0.
You can install 8.99 beside 8.0.6 and use it just for step export. We’ve done this for exactly the same reason as you. Just don’t save the board when you’ve opened it in 8.99.
