New to the forum & fairly new to EDA in general. Is there a way to export the “Cu only” from a board (e.g. what I see in the 3d view below) as STL or some other solid model format…or perhaps access it via the Python Scripting Console and export it that way? The application is for mechanical simulations.
MitjaN - Thank you! - this looks to be EXACTLY like what I am after. I was trying out StepUp and noticed the imported features weren’t solids and seemed to lack vias…I will give facd_pcb a shot.
So it looks like fcad_pcb is doing what I want…only exception is that it hasn’t created the oval pads (compare below to original image from KiCAD)…anyone had experience with this or is there something I am missing…again thank you so much in advance.
